12 members (Joe H, Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible),
103
Mod | | | Forums66 Topics128,169 Posts1,057,037 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 5 New Guy | | New Guy Joined: Oct 2007 Posts: 5 | Hello everyone. I'm a retired GI thats attending the auto mechancis class at my local community tech college. I'm rebuilding the 235 engine in my 59 Chev 1/2 ton. The crank is out of tolerance. But that's easy, I'm sending that to be ground. But the cam lobes are worn and starting to pit on the edges. I called the supplier my instructor usually uses. They can get me a new cam, but it doesn't come with the followers or lifters. The guy said they haven't made those lifters in about 5 years. Could anyone recommend a trusted and good quality source of a new cam with followers and lifters? | | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | I got my cam from http://www.patricksantiquecars.com/Phil is the owner's son I believe and he is very enthusiatic about inline 6 engines. I have found that everyone has their opinion and he is no different, but he did not steer me wrong. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Didn't the later 235's in trucks,such as the 59 use hydraulic lifters? Samantha | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not according to the shop manual, specs are still listed for solids. V8s were hydraulic, though.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | As Bill stated above, all truck 216/235/261 engines had mechanical (solid) lifters. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | How much swappin' around of different can be done and is it benificial? The early power glide cams seemed to offer a little more power than those in the trucks. Using a solid lifter with a hydralic cam shouldn't present any problems, I wouldn't go the other way around though. Does Patrick's offer stock cams besides the performace cams they sell? Denny G
Denny G Sandwich, IL
