Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, Barney1951, Jaison, 1 invisible), 42 guests, and 5 robots.
Topics128,010
Posts1,055,305
Members48,419
#468393 11/06/2008 4:15 AM
Hello,
I have looked and searched thru the bolt search engine, and the tech tip section, but cannot find an information about casting numbers for GM transmissions. I would like to find out the year and the difference between the two I have. Any help would be appreciated.
Kevin wave
mo2cyl #468591 11/06/2008 9:48 PM
Post some photos of them and offer the descriptions of each. Most of the mind readers around here have taken the day off, smile
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #468872 11/07/2008 5:45 PM
OK, what mo2cyl is wanting to know is are there any books or written resources for GM trannys. I do not know of any but if you do then please respond to mo2cyl.
Thank you.
Dave
53moneypit #468879 11/07/2008 6:28 PM
Mo2Cyl,
Hve you tried a google search, something like GM Manual transmission, 3 speed. You'll get a lot of hits but I've found that the hits for transmission rebuilders will usually have pictures or good descriptions of the transmissions they work on.
I know when I was looking for information on a Muncie 4 speed, a couple of site i hit had casting information and pictures along with gear ratios and which vehicles they came in originally.
Hope it helps
Gary,
Kelly, and Family
I will check some other sites and let you know what I find.
Thanks Dave and Gary
