| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Hello, I have looked and searched thru the bolt search engine, and the tech tip section, but cannot find an information about casting numbers for GM transmissions. I would like to find out the year and the difference between the two I have. Any help would be appreciated. Thanks Kevin  Kevin
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Post some photos of them and offer the descriptions of each. Most of the mind readers around here have taken the day off,  | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | OK, what mo2cyl is wanting to know is are there any books or written resources for GM trannys. I do not know of any but if you do then please respond to mo2cyl. Thank you. | | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | Mo2Cyl,
Hve you tried a google search, something like GM Manual transmission, 3 speed. You'll get a lot of hits but I've found that the hits for transmission rebuilders will usually have pictures or good descriptions of the transmissions they work on.
I know when I was looking for information on a Muncie 4 speed, a couple of site i hit had casting information and pictures along with gear ratios and which vehicles they came in originally.
Hope it helps
Gary, Kelly, and Family
| | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | I will check some other sites and let you know what I find.
Thanks Dave and Gary
Kevin Kevin
