1 members (Ole49GMC), 109 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#466915 11/01/2008 1:00 AM
Apprentice
Apprentice
Hey guys, I just took apart my rocker arm assembly and the shafts are quite worn on the bottom sides. Does anybody have any suggestions or resources to get them replaced. Just talked to a machine shop that would charge me $280 per side to machine new ones.
What engine is this for??
The rocker arm shafts were worn on my 235 when I rebuilt it, NAPA had no trouble finding new ones for me.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Apprentice
Apprentice
Dear Buffalo;
This is normal for the older (low pressure) engines.
Good (used) sets are around cheap and in the later 235/261 are the same. You might find some new sets too.
Either way; $560 is way to much money, so "go shopping"..
Good luck, John M...
"There are no shortcuts to any place worth going"; Anon....
Look through the vendor list, some of them carry new rockers and assemblies.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
lil buffalo,
Neither your profile nor your posting mentions the type of engine. Assuming it is 1940-1962 216/235/261, Jim Carter sells a shaft that will cost you less than $40 for two, delivered.
Tim
lil buffalo i have 4 vintage shaft kit's with bushing,s 1940-1941 and 2 1937-1939 kit's with bushing's in the box ,there again what engine are we talking about i can e-mail picture's of the kit to you if you are interested
Apprentice
Apprentice
Thanks for your reply. I have talked to napa and they do not have any shafts. Do you know where they found them. Napa does not have them.
Apprentice
Apprentice
I suspect they could be the same. You talk about bushings. I don't know what the bushings would be. If you could email pictures, that would be great. Put a ruler next to them so I can see their size.
I don't know where NAPA got them, I remember them being a "stock" item, meaning they did not have to look very hard. again, this was for a 55 model 235.
You still haven't told us what engine you have??? Hopefully it's not a 30's ford V8, then we'd all look pretty stupid right now...
Grigg
---All pictures---
A very little bit of research reveals this member has a 55/1st with a 235 in it. I have enclosed a link to a CSK (Kragen) page that shows the replacement rocker shaft along with it's price. This took about 40 seconds for me to find and I'm dumber than a post! smile
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=SEA&MfrPartNumber=RS602
Stuart
Same here Stu, and I'm dumber than the stump! http://www.oldchevytrucks.biz/47_55/full.asp?page=98
$13.44 each.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Stuart: 40 seconds? To check lil' B's profile for having a'55 or to find the part? Or, both? cool
$21 plus shipping (per shaft) - use part number RS602 on the Parts America page (linking to their parts in their catalog does not work).
The Jim Carter price on this item (which was posted a few days ago) is a good enough price, even with shipping.
I bet if someone finds a NAPA part number, the cost will be higher there (and, my local NAPAs now charge shipping if it is not in a local warehouse).
Tim
Hey Tim, 1min. 40sec., Obsolete Chevrolet Part Co.
http://www.parts123.com/PartFrame.a...com&TITLE=Obsolete_Chevrolet_Part_Co
$16.00 each.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I had NAPA check on some for my 235 and they were over $155 each. They could not tell me if that was an assembly or shaft only. In fact they couldn't tell me anything except that they were available and the price. So I bought one from Rock Auto Parts online on a Tuedsay, had it on Thursday and paid $14 for it. You can see the parts they offer in their engine listing.
NAPA is my source of last and most expensive resort. Good guys but then so am I...that and a buck and half will get you a small coffee.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Although the original question dealt with only the rocker shaft, from a do-it-right standpoint, it would seem to me that a new shaft mated with the old scored bores of the rocker arms would only be a 'half-fast' repair.
Stuart
sent two emails with pictures
