1 members (CuzzFuzz),
83
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 22 Apprentice | | Apprentice Joined: Aug 2008 Posts: 22 | Hey guys, I just took apart my rocker arm assembly and the shafts are quite worn on the bottom sides. Does anybody have any suggestions or resources to get them replaced. Just talked to a machine shop that would charge me $280 per side to machine new ones. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What engine is this for??
The rocker arm shafts were worn on my 235 when I rebuilt it, NAPA had no trouble finding new ones for me.
Grigg | | | | | Joined: Dec 2006 Posts: 16 Apprentice | | Apprentice Joined: Dec 2006 Posts: 16 | Dear Buffalo;
This is normal for the older (low pressure) engines.
Good (used) sets are around cheap and in the later 235/261 are the same. You might find some new sets too.
Either way; $560 is way to much money, so "go shopping"..
Good luck, John M...
"There are no shortcuts to any place worth going"; Anon....
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Look through the vendor list, some of them carry new rockers and assemblies. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | lil buffalo, Neither your profile nor your posting mentions the type of engine. Assuming it is 1940-1962 216/235/261, Jim Carter sells a shaft that will cost you less than $40 for two, delivered. Tim | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | lil buffalo i have 4 vintage shaft kit's with bushing,s 1940-1941 and 2 1937-1939 kit's with bushing's in the box ,there again what engine are we talking about i can e-mail picture's of the kit to you if you are interested | | | | | Joined: Aug 2008 Posts: 22 Apprentice | | Apprentice Joined: Aug 2008 Posts: 22 | Thanks for your reply. I have talked to napa and they do not have any shafts. Do you know where they found them. Napa does not have them. | | | | | Joined: Aug 2008 Posts: 22 Apprentice | | Apprentice Joined: Aug 2008 Posts: 22 | I suspect they could be the same. You talk about bushings. I don't know what the bushings would be. If you could email pictures, that would be great. Put a ruler next to them so I can see their size. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't know where NAPA got them, I remember them being a "stock" item, meaning they did not have to look very hard. again, this was for a 55 model 235.
You still haven't told us what engine you have??? Hopefully it's not a 30's ford V8, then we'd all look pretty stupid right now...
Grigg | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | A very little bit of research reveals this member has a 55/1st with a 235 in it. I have enclosed a link to a CSK (Kragen) page that shows the replacement rocker shaft along with it's price. This took about 40 seconds for me to find and I'm dumber than a post! http://www.partsamerica.com/ProductDetail.aspx?MfrCode=SEA&MfrPartNumber=RS602Stuart
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Stuart: 40 seconds? To check lil' B's profile for having a'55 or to find the part? Or, both? $21 plus shipping (per shaft) - use part number RS602 on the Parts America page (linking to their parts in their catalog does not work). The Jim Carter price on this item (which was posted a few days ago) is a good enough price, even with shipping. I bet if someone finds a NAPA part number, the cost will be higher there (and, my local NAPAs now charge shipping if it is not in a local warehouse). Tim | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I had NAPA check on some for my 235 and they were over $155 each. They could not tell me if that was an assembly or shaft only. In fact they couldn't tell me anything except that they were available and the price. So I bought one from Rock Auto Parts online on a Tuedsay, had it on Thursday and paid $14 for it. You can see the parts they offer in their engine listing. NAPA is my source of last and most expensive resort. Good guys but then so am I...that and a buck and half will get you a small coffee. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Although the original question dealt with only the rocker shaft, from a do-it-right standpoint, it would seem to me that a new shaft mated with the old scored bores of the rocker arms would only be a 'half-fast' repair.
Stuart | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | sent two emails with pictures | | |
