2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 13 New Guy | | New Guy Joined: Mar 2004 Posts: 13 | I was removing the rear fenders from my 1950 suburban and broke off most of the bolts holding them on. Does any one have a good Idea of how to get them out without doing major damage to the bolt hole.
Anthony McCants
1950 Chevy Suburban
| | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | Worked for me. Get a can of Aerokroll, spray liberally leave for several days and spray again. Then grab the bolts remains witha vice grip and they should turn out. I even used it on a pitman arm and didn't need a wheel puller. If that doesn't do it or you can not grag the remains of the bolts with grips, spray again and drill out center of bolt and use an easy out. Good luck to you. Richard
Richard J Patrick - 1946 Suburban
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | yep, good luck Richard. Man, all mine twisted off on the panel and I gave up. The body man is going to cut the old ones out, and put in metal with new bolts welded to the back. Says its not a big deal. Since he was offering and we had already agreed on teh price I figure why should I worry.
As prat35sc says though, good luck. HOpe yours comes out a lot easier. | | |
