1 members (klhansen), 90 guests, and 0 robots.
Topics128,050
Posts1,055,641
#468205 11/05/2008 4:06 PM
8
8 Offline
I was removing the rear fenders from my 1950 suburban and broke off most of the bolts holding them on. Does any one have a good Idea of how to get them out without doing major damage to the bolt hole.
Anthony McCants
1950 Chevy Suburban
89cutlass #468214 11/05/2008 4:27 PM
Worked for me.
Get a can of Aerokroll, spray liberally leave for several days and spray again. Then grab the bolts remains witha vice grip and they should turn out. I even used it on a pitman arm and didn't need a wheel puller. If that doesn't do it or you can not grag the remains of the bolts with grips, spray again and drill out center of bolt and use an easy out. Good luck to you. Richard
Richard J Patrick - 1946 Suburban
rpat356sc #468217 11/05/2008 4:33 PM
yep, good luck Richard. Man, all mine twisted off on the panel and I gave up. The body man is going to cut the old ones out, and put in metal with new bolts welded to the back. Says its not a big deal. Since he was offering and we had already agreed on teh price I figure why should I worry.
As prat35sc says though, good luck. HOpe yours comes out a lot easier.
