| | | Forums66 Topics128,049 Posts1,055,629 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | does anyone know how hard the aftermarket ubolts are. i have to replace mine. i can get grade 5 but i didnt know if i should look for grade8. will the grade 5 be ok i know grade 8 is harder and that would be better but will grade 5 be ok 54 chevy 1.5 ton
thanks | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | In my opinion grade 5 should be fine. Grade 8 is harder, but also more brittle. 50 years ago lots of u bolts were made in small town shops out of plain old cold roll and I never heard of one failing. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 54 big truck,
I had the same question myself. I went to the local blacksmith/spring shop where they make them to order...I asked what material they used. They told me they use 4140. I made my own out of 4140. I don't actually know what a stock u-bolt is made from but Crenwelge might be correct.
Stuart
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | check out the trailer places and parts houses. Most have something you can use hanging on a shelf. Even Notthern Tool and few other places. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I think most spring shops make ubolts from grade 5 steel. It will stretch before it breaks. Grade 8 is too brittle. About that 4140 steel - isn't that Chromium -Molyb denum? That's strong stuff they make tubular chassis from. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Some years ago when we were still running spring ride Hutch suspension on our trailers they went from a 7/8 to a 3/4" high tensile U bolt for weight savings. We speced our trailers with single leaf springs which broke quite often, and we always used new u-bolts. That left lots of u-bolts laying around. We have bent them in all kinds of shapes, the high tensile included, in a hydraulic press to make some special hook or something and never had one to break in the press. This leads me to believe they were no harder then 5. Grade 8 won't take much of a bend and it snaps like glass. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I just went to a truck spring shop. They made them right there. They had stock lengths of material, and a hydraulic press. Violia. It wasn't expensive either. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know how one would make a U bolt out of stock. The stock bolts that the spring shops bend into shape have a shank that has a smaller diameter than the threaded portion. This is to allow the non threaded portion to stretch before the threaded portion. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | We still have a lot of NOS U Bolts that were specific to an application of trucks and trailers that we have retired long ago. The old ones have the shank the same size as the threads, and these were OEM replacements for Dayton, Reyco, etc. suspensions. The old Fruehauf F2 suspension also used u bolts with the shank the same size as the thread. | | |
