2 members (Guitplayer, Hush),
106
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46799 06/24/2005 4:32 AM | Joined: Jun 2005 Posts: 2 Junior Member | | Junior Member Joined: Jun 2005 Posts: 2 | I have a 1963 c-10 with the in-line 6cylinder it sat for 8 years before I got it and it cranks but doesn't start.. I can spray starter fluid down the carb and it will run for a little bit..I put gas in it..were should I start?
I'm a virgin to the classic truck life..be easy on me
#46800 06/24/2005 5:29 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Fuel pump. It may take a while to get the fuel from the tank to the carb. Run it for awhile with just the starting fluid and see if you can get the pump to pick up. If that doesn't work, take off the fuel line to the carb and turn it over to see if fuel is flowing. If so, your carb may need a rebuild. After 8 yrs it prolly will. Check the fuel filter too if it has one. | | |
#46801 06/24/2005 5:36 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Welcome to the bolt! I would try a remote fuel source. You can use a plastic gas can. Get a couple feet of rubber fuel line. Attach to the inlet on the carb and attach to the vent nipple on the gas can. Make sure you don't have any leaks. Also make sure you have a working Fire Extinguisher with you!!! Try running it this way. If this works then you either have a plugged fuel line, bad fuel pump or a ton a "junk" in the tank plugging up the works.
Just a note: You may want to disconect the fuel line at the carb and place it in a bottle and then crank the engine and see if you are getting any fuel. If you do then it maybe the carb is the problem. If you don't get any fuel make sure to disconnect the fuel line from the tank to the pump . Just in case you start the truck with the remote fuel can you don't need the fuel pump "clearing" itself and start pumping fuel.
What ever you do, take your time and BE SAFE!
Good luck and once again Welcome to the Bolt!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#46802 06/24/2005 10:53 PM | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | I wouldn't use the starting fluid for a very long time ae over and over it can do damage to the rings. What happens if you pour gas down the carb and try to start it?
super250six | | |
#46803 06/24/2005 11:44 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Sometimes it works, but other times it sets the truck on fire. | | |
#46804 06/25/2005 3:18 AM | Joined: Jun 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 38 | Sounds to me like it's time for a carb kit. | | |
#46805 06/25/2005 3:57 AM | Joined: Jun 2005 Posts: 2 Junior Member | | Junior Member Joined: Jun 2005 Posts: 2 | thanks for the help...I'll let you know what happens
