2 members (Rusty Rod, porsche),
64
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | I have a 1962 Chevrolet truck 6 cylinder, 3 speed, on the column with OD on the dash. I have been having an eratic speedometer. It holds steady for a while then goes back and forth any suggestions? Tulsa | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Unless it's making noise it's probably not the cable. If lubing doesn't help you'll probably need to have it rebuilt.
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Does the 'back and forth' correspond to when you're scratching something?  | | | | | Joined: Apr 2008 Posts: 27 Apprentice | | Apprentice Joined: Apr 2008 Posts: 27 | No I do not think I have any particular itch that would contribute to the eratic behavior of the speedometer. I will try the lubrication route first then maybe some foot powder! Thanks!!  | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My speedo does the same thing, please send me your left over foot powder. | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | No Kidding....When mine acted like this, the advise was to push some vasoline into the back of the speedo where the cable goes, reattach cable. It works! | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | You might also check the path of the speedo cable.....my needle will fluctuate if the cable housing is moved from side to side. Once I return it to it's favorite spot it's as steady as a rock.
As for grease on the cable....I think the recommended lube is a graphite based powder that won't stiffen up with cold weather.
Dave | | | | | Joined: Oct 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 88 | I also have a 62. Mine was doing the same thing, tried to lube it, no help, finally snapped the neddle off of it. had to replace the speedo. I figured it was worn out because it howled like a dog, a BIG dog when it was cold. | | |
