5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#466393 10/30/2008 3:51 PM
ever turn signal that you can buy after market I don't like they look cheesy. I was wondering if you can adapt the parts from a 54 signal switch to my 53 or do I need to get the whole column?
Riding in the Passing Lane
Yes you can adapt the latter turnswitch to your truck. There is a set screw under neath it that loosen it up.
1972 Chevy c10 Cheyenne Super
If I'm not mistaken, the turn signal assembly is the same up to '59.
Bill Burmeister
Ya know you have the most reliable turn indicator attached to your left shoulder. It never fails to work and is user friendly.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
I thought in one of the catalogs you could buy everything for the 54 turn signals the cup everything sits in, the lever, the switch itself, and the cancellation thing-a-ma-bob. But I can't find the cup. I see everything else
Here is a complete (no lever/knob) 1954-56 tuck turn-signal unit.
http://www.classicparts.com/1954-56-Turnsignal-Cup-Assembly/productinfo/53-531A/
The 57-59 unit has different electrical connectors.
This knob/arm is described as being just like the original, but the knob is not as "sleek" as the original 54/55 knob.
http://www.classicparts.com/1954-59-Turnsignal-Lever-w_-Knob/productinfo/29-555/
caroline broke the handle off the original one we got w/ the truck
here is my ebay buy and she works just fine. I drilled a hole & tapped it to hold the assy to the column.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=20.jpg
Jim & Caroline
Just so ya know, you cant use a '54 or later switch on the column without using the steering wheel as well. Well you probably could, but it would look ugly.
The '54 and laters had a cup portion that all the turn signal gizmos sit in and that mates or matches up with the back side of the steering wheel. I wanted to use one out of a '56 (which is the same) and it wouldnt mate up with the back side of the steering wheel. There would have been a rather large, ugly gap.
Jeff
My 1953 Chevrolet
1947.1 Gallery
54 steering colums are larger in diameter check this blinker switch out http://i464.photobucket.com/albums/rr5/resurrectionvintageautoparts/turnsignallikeguide6004.jpg
1949 SUBURBAN
