7 members (Otto Skorzeny, Paul_WNC, WICruiser, TUTS 59, GRNHydra, Phak1, 1 invisible),
182
14
Mod | | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 37 New Guy | | New Guy Joined: Aug 2005 Posts: 37 | Need your input on this one - just finished rebuilding my 216 engine and now that everything is clean and painted all nice, I have a leaking water pump. Leak is very small - fluid is detected on the pump body behind the pulley. It leaks down the pump body to the block and eventually wicks along the oil pan flange. Anyway, its an original pump. Any ideas where/who could repair this type of pump? Or, is it better to just get a new "modern" pump from Filling Station, JC, NAPA or elsewhere?
49 Truck Nut
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Run it a while. Sometimes the leak will stop on its own. The seal is a spring-loaded carbon ring running against a ceramic face, and occasionally it takes a little run time for the running surfaces to mate again after being out of operation for some time.
It'll get better- - - -or a lot worse- - - -in a few hours of run time! Jerry
| | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | just put a tiny amount of black pepper in it will seal the leaks. as long as they are small leaks. My uncle told me about it. works pretty well. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you end up having to replace the water pump they are available at your FLAPS.
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | The old pumps (like yours) can be overhauled but it is not cost efficent. So a visit to the local parts house is in store. My grandpa swore by the black pepper (temperary repair). But as a more permanent repair replace the pump. What ever you do never NEVER!!!!!! use liquid glass or stop leak on your vehicle unless all other means or repair are exhausted.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | +1 on the not ever using the stop leak stuff. | | | | | Joined: Sep 2007 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 154 | I am restoring a 1946 chev fire truck pumper. I bought it with the thought that it was a 216, however it may be a 235. That being said the water pump began leaking a yr. ago. I went to my Car Quest parts store and they were able to replace it with a rebuild. They told me it came out of chicago. I think it cost me fifty dollars exchange. | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | they are around and not to expensive- I always keep a spare, along with a couple gaskets | | |
