0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#462860 10/19/2008 1:02 AM
Need your input on this one - just finished rebuilding my 216 engine and now that everything is clean and painted all nice, I have a leaking water pump. Leak is very small - fluid is detected on the pump body behind the pulley. It leaks down the pump body to the block and eventually wicks along the oil pan flange. Anyway, its an original pump. Any ideas where/who could repair this type of pump? Or, is it better to just get a new "modern" pump from Filling Station, JC, NAPA or elsewhere?
49 Truck Nut
Run it a while. Sometimes the leak will stop on its own. The seal is a spring-loaded carbon ring running against a ceramic face, and occasionally it takes a little run time for the running surfaces to mate again after being out of operation for some time.
It'll get better- - - -or a lot worse- - - -in a few hours of run time!
Y
Y Offline
just put a tiny amount of black pepper in it will seal the leaks. as long as they are small leaks. My uncle told me about it. works pretty well.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Ex Hall Monitor
Ex Hall Monitor
If you end up having to replace the water pump they are available at your FLAPS.
The old pumps (like yours) can be overhauled but it is not cost efficent. So a visit to the local parts house is in store.
My grandpa swore by the black pepper (temperary repair). But as a more permanent repair replace the pump.
What ever you do never NEVER!!!!!! use liquid glass or stop leak on your vehicle unless all other means or repair are exhausted.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Y
Y Offline
+1 on the not ever using the stop leak stuff.
I am restoring a 1946 chev fire truck pumper. I bought it with the thought that it was a 216, however it may be a 235. That being said the water pump began leaking a yr. ago. I went to my Car Quest parts store and they were able to replace it with a rebuild. They told me it came out of chicago. I think it cost me fifty dollars exchange.
Y
Y Offline
they are around and not to expensive- I always keep a spare, along with a couple gaskets
