5 members (Nuts&Bolts, Joe H, Shade Baby, baldeagle, dt235sd), 88 guests, and 1 robot.
Topics128,014
Posts1,055,331
Members48,419
#465302 10/27/2008 12:57 PM
Sealed system with expansion tank and 16# cap.
Any reason not to set this up?
Avette4me #465309 10/27/2008 1:28 PM
16# seems allot to me , but the experts will chime in soon.
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #465328 10/27/2008 2:15 PM
Depends on how good your system is!!!! I only run a 4lb but my radiator has a new core but the ORIGINAL thin top and bottom tanks!
I'd say a 14lb should be gosh plenty! If I remember correctly every lb of cap pressure raises the boiling point 12 degrees BUT DON"T QUOTE ME ON THAT.
Achipmunk #465362 10/27/2008 3:23 PM
What year engine and radiator?
tclederman #465405 10/27/2008 5:55 PM
I see no reason for that kind of pressure. A good 50/50 premix coolant will raise your boiling point to where you should never approach it. For what you gain in raising the boiling point, you lose by running the risk of blowing hoses, heater cores, etc.
crenwelge #465643 10/28/2008 12:08 PM
I'm torn. 16 sounds a bit high to me as well, but nearly all modern cooing systems use it. Maybe I'll look for a little less...
Radator is original and engine is 350 out of a 1980 vette. I will likely replace the radiator with a new one.
Avette4me #465653 10/28/2008 1:39 PM
If you are not using the original radiator nor the original heater, you should be safe with higher pressure as long as the engine, new radiator (and new heater core) are for vehicles that ran with higher pressure.
tclederman #466328 10/30/2008 11:52 AM
Problem solved. I got a 7 pound cap without the flip up pressure release.
