| | | Forums66 Topics128,163 Posts1,057,072 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 11 New Guy | | New Guy Joined: Apr 2007 Posts: 11 | Does anyone have any suggestions on what to do if this truck is stored for 5 to 6 months in northern Arizona. I used to store this truck up north for the winter, No problem there.
Thanks Larry Wilke 1952GMC 101 1959 Edsel Ranger 2DR and 1956 Dodge Lancer Custom Royal (in progress)
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | should be less of a problem in arizona as dry as it is. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2008 Posts: 15 New Guy | | New Guy Joined: Mar 2008 Posts: 15 | | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Larry, you don't say if your truck will be inside or out,but as Joe said, a cover might not be a bad idea. I'd be tempted to place it on jackstands to avoid the tires 'flatspotting' Maybe open the cowl vent a tad, just to allow some air circulation. I wouldn't open any windows in case some critters get in! Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | would definitely cover the tires, sidewalls will dryrot for sure | | | | | Joined: Apr 2007 Posts: 11 New Guy | | New Guy Joined: Apr 2007 Posts: 11 | The truck will be stored in a insulated garage (no air conditioning). I plan on using jack stands. I was wondering about the engine, gaskets etc drying out. I had a cover for the truck.
Larry 1952GMC 101 1959 Edsel Ranger 2DR and 1956 Dodge Lancer Custom Royal (in progress)
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | the last bit of gas you keep in her should be of good quality like chevron ethyl high test and only a gallon (or two). make sure it runs thru the carb before the final shutdown. along w/ a touch of stabil. make sure the oil was changed too. that way when you go to restart it and put say 5gal in the 6 mo. old mixture is not so 'stale'.
put a 1/4 of gas in a dish outside and watch it for a couple days. HUMMMMMMmmmmmmm.......
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2001 Posts: 3,615 Moderator | | Moderator Joined: Aug 2001 Posts: 3,615 | I'd also throw a few mothballs in the cab, engine compartment and a couple along the frame rails. These seem to do a good job of keeping the unwanted squatters out.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | |
