7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Hy all. I 1998 S10 ZR/2 as a daily driver and the serpentine belt squeels when you first start it up. I have changed the belt twice, the crank pulley,water pump and pulley,Idler,and belt tensioner also had a new air conditioner compressor installed. The only pulleys that haven't been changed are the altenator and power steering pulleys. Sometimes the belt stops squeeling when it gets good and warm, but then it starts all over when the engine cools off.Has anybody got any ideas that I could try to stop the squeeling? I know the truck is kind of new for this sight, but just I thought would ask. thanks Eric | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | One of the belts that i tried was a GM OEM belt . It still didn't stop. Sorry it's a 4.3 V6. | | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | had the same problem on a 99 tahoe, 5.7 and i cleaned all the pulleys with a small wire brush, squeel went away.. | | |
