3 members (Gdads51, gswbbc, Hotrod Lincoln), 142 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#465178 10/27/2008 12:56 AM
Do you recommend dual carbs for a 235 inline six. Does it improve the performance a lot? what about gas milage?
Richard Gaglio
1 Offline
I love my Cater / Webers from Tom Langdon. I did all of my conversions at one time so, determining which was the money best spent, I'm not sure. I'm only getting about 15 mpg but I'm still tweaking on it. Probably my favorite upgrade was the HEI I like getting in and it starting right up, no grinding away to start!! You can't go wrong with Longdon's stuff give him a call he's extremely informative.
1954 Chevy 3100
1952 Chevy Suburban
I've been running a dual Carter/Weber setup on my 235 for the past 7000 miles......eliminated all of the issues with the stock Rochesters. My fuel mileage hovers around 18....the E10 fuels put an end to my visions of 20+.
As for "performance".....if you mean "kick-in-the-pants" type stuff you might be disappointed. However, getting a clean burn on all cylinders, decent mileage, and the "WOW" factors at all the shows from folks that have a history with the Chevy 6.....priceless!!!!!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Although you may up your gas mileage a little by changing carb setups,the real results will come when you change your final drive,rearend to a higher gear.Most of the old trucks even the 1/2 tonners used at least a 4;11 rearend and some even around the 4:56 mark.My 55 is still running a stock 3:90 rear,which will cause it to lose a lot on gas mileage. However I am also using an overdrive 700R4 tranny which works out just fine.Way too many people on this site thinking that carberation is the answer to fuel economy.First things first,check to see what rearend gears you are running.Get that gearing up to about 3:42 or even 3:08,and you will see a big difference.
