0 members (), 62 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#465265 10/27/2008 5:36 AM
Was going to take the truck out for a short ride today(last warm weather for a while)and after it fired up I noticed fuel leaking from around the inlet port on the carb. Grabbed a wrench to tighten it up, and that's when it broke. Tightened too tight, and where the filter is in the carb body, the threads said later. So now it's going to take a new carb or I'll be looking for a part on the carb to replace the one that's on there now. 64' w/230, Rochester B? I think. It's always something.
dj durant
More pix on Flickr
Tramp #465286 10/27/2008 11:50 AM
did the same thing on my 64 w/292 had to buy new carb
joek3167 #465307 10/27/2008 1:23 PM
on the mid 70's 2 barrels an quadrajets there was a fitting made you could get a NAPA that replaced the carb inlet filter with this fitting that would self tap into the carb and fix this problem but then after the fact a good cleanin of the carb an a in line filter was needed ..Your post reminded me of a Bud that stripped out his carb on a 78 camaro..an fixed as said.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #465361 10/27/2008 3:22 PM
OK and thanx folks. Looks like I'll be on the phone this a.m. searching for the parts to fix the carb I have. I just replaced it last winter, and it's been doing a good job. Something will come of it all, just missed out on a good day for a ride. Went from near 70 on Sunday to in the 20's last night.
dj durant
More pix on Flickr
Tramp #465375 10/27/2008 4:03 PM
Try installing the fitting with some good epoxy like JB weld. Let it set up good then install the fuel line. It should get you by for awhile. You can also tap out the hole to the next bigger size and adapt back down, it might save you from buying another carb. Joe
Joe H #465432 10/27/2008 7:53 PM
Might try a helicoil with the green loc-tite on the outside.
Tapping for a larger fitting was a good idea too. Otherwise they sell this stuff called "Lab Metal". It hardens up like metal and has the appearance of dull aluminum. It is workable and can be tapped for use for repair. Just can't have it over 350 degrees.
http://www.neverseezproducts.com/labmetal.htm
trump #465591 10/28/2008 3:57 AM
I stopped by the FLAPS and the gal behind the counter had just what I needed. It's an oversize fitting, self tapping, and when I go back in the a.m. I'll make sure and post the part number for all of you that may find yourself in the same situation. All I have to do is make sure and take the time to keep things good and clean when I do the install and keep the shavings out of the guts.
dj durant
More pix on Flickr
