4 members (Jon G, 5 Window 9434, Charles in CA, dt235sd), 54 guests, and 0 robots.
Topics128,049
Posts1,055,635
#464969 10/26/2008 4:43 AM
hi guys
was pondering the idea of doing a bearing conversion on my 54 1.5 ton. does anyone have the bearing numbers for this conversion. i have gone through the national bearing book but with no success on sizes of the bearing and races.if this has been talked about im sorry but i did a search and seem to find the answer.
thanks for any help
fil
Are you talking about wheel bearings? If so, front or rear, if rear is it a single speed or 2 speed?
sorry i should hae mentioned front wheel bearing my truck is a 54 1.5 ton dually. i have the front end out right now getting new king pins installed and some other stuff being made and the bearings got my mind going
thanks
54,
What are the bearing numbers you are trying to convert from ?
Are those stock bearings a tapered roller bearing but rollers are not flat instead they are barrel shaped, like a whiskey barrel ?
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
glasman #465012 10/26/2008 12:36 PM
yes i want to convert from the stock ball bearings to tapered bearings
Get a bearing number. It can be one of two numbers depending if you have the heavy front axle. Call these guys. We buy hard to get bearings from them and they deal in quality stuff. http://www.baumhydraulics.com/home.php
