7 members (TexasA&M48Truck, Bill Hanlon, Shade Baby, Nhluvstruck, Brian Moore, Wally / Montana, 1 invisible),
227
Mod | | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | hi guys was pondering the idea of doing a bearing conversion on my 54 1.5 ton. does anyone have the bearing numbers for this conversion. i have gone through the national bearing book but with no success on sizes of the bearing and races.if this has been talked about im sorry but i did a search and seem to find the answer.
thanks for any help fil
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Are you talking about wheel bearings? If so, front or rear, if rear is it a single speed or 2 speed? | | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | sorry i should hae mentioned front wheel bearing my truck is a 54 1.5 ton dually. i have the front end out right now getting new king pins installed and some other stuff being made and the bearings got my mind going
thanks
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | 54, What are the bearing numbers you are trying to convert from ? Are those stock bearings a tapered roller bearing but rollers are not flat instead they are barrel shaped, like a whiskey barrel ? Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | yes i want to convert from the stock ball bearings to tapered bearings | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Get a bearing number. It can be one of two numbers depending if you have the heavy front axle. Call these guys. We buy hard to get bearings from them and they deal in quality stuff. http://www.baumhydraulics.com/home.php | | |
