2 members (55shaker, Paul_WNC),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Hello!
I've often heard that 41 - 46 panel trucks were equipped with front stabilizer bars. I am considering doing some upgrades to my truck and was wondering if this would make a noticable improved to the handling.
Thanks in advance. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | steering stabilizer ?
i installed a steering stabilizer on the front of my 57 and i love it.
leonard | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Randy,
I dont even know what it would consist of. Any chance you can shed some light on it for us dim bulbs out here? All I know is that I take a ride in my car and I have to drive my truck. You certainly know when you hit a bump and if it is big you better have your hands on the wheel.
Tim
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sounds like you guys are talking about a steering damper,rather than an anti-roll bar. Basically it's a shock absorber for your steering. VW used them on their Bugs,and a lot of off road guys use them. It's takes the feedback from those big 'ole wheels and tires and stops the shock loads transmitting back up the steering to your hands.It smooths the steering out,no end! It wouldn't be too hard to retrofit this addition as there are kits available. Try looking at some off-road parts vendors. Sorry none spring to mind at the moment.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | Or are you talking about a Sway bar? They did have them back then but I haven't ever seen one. I would like one for my '37, it really lays over going around corners! Joe | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Randy, If you are talking about a stearing stablizer, you might want to check all your stearing componets first. Make sure your tie rod ends and draglink are in good condition and adjusted right. Also radial tires would help. I have all original style stearing componets on my truck and have no problems at all with any kind of bump stear. Now if you are looking for an anti-sway bar I have been told that one for a 47 will fit the 41-46 frame with a few modifications. Any of the regular vendors would have them. I have thought about this upgrade myself but I'm not too sure about the modifications that would be necessary. I hope this helps George | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Burbs of the era had "anti-sway" bars installed from the Factory. If you can't locate one of those, then pick up an AD sway bar kit from Jim Carter's etc. Ray Stanley(metalman) put onto my '45 GMC and it is the cat's [censored]. The trailing ends bolt into the axle with no mods. Then the front needs to be adapted to the frame. Ray made some plates up to put on the bottom of the frame horns. http://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/237106068/m/2271018851?r=4501002951#4501002951If you're an OGMC site member, use the link. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | "Chevrolet Shop Manual, 1942-48 Passenger Cars & 1942-46 Trucks" Page 3-19 and 3-20 has three paragraphs on the 1/2-Ton Panel Truck Stabilizer. http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm319.htm Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | My 1946 Chevy Suburban School Bus has a front sway bar. I thought it was an added accessory due to the fact that it was built to be a school bus from day one.
It required special hardware to mount it to the frame. | | |
