6 members (RAC1812, HandyAndy, Peggy M, 1955 1 Series, Otto Skorzeny, Bill Marlow), 190 guests, and 1 robot.
Topics128,087
Posts1,055,982
Members48,430
#464124 10/23/2008 12:48 AM
Hello all,
Just recieved my new set of 10 rubber hood bumpers. Went to install them on my '50 half ton and found where the 6 flat type bumpers go (in the middle on either side of the hood) but don't know where the other 4 larger "can like" bumpers go. There are no other empty holes that I could see along the hood edge.
Help!?!?
Spot
Spotbiltxo #464153 10/23/2008 1:44 AM
The larger ones usually go at eh forward edge of the hood on the latch support/grille area.
Bill Burmeister
LONGBOX55 #464261 10/23/2008 2:33 PM
Yup, What Bill said
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #464484 10/24/2008 4:34 AM
I looked again tonight at the hood and there are no extra holes for bumpers. I did notice two holes on either side of the spring latch mechanism but the bumper stems would are too small and will not hold to keep the bumpers in place. I looked throughly and saw no extra holes anywhere.
Does anyone have a photo of their hood showing the placement of the bumpers? Please post if you do.
Spot
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Spotbiltxo #464523 10/24/2008 11:19 AM
Six flat ones:
http://rides.webshots.com/photo/2343730410098611668ObCSMc
Four tall ones:
http://rides.webshots.com/photo/2875137580098611668WKvfJy
A picture is worth a thousand words.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
No wonder I couldn't find where the 4 large bumpers went......there are bolts in ALL the holes on my truck!!
I guess the previous owner put them there not knowing bumpers
were to go there instead of bolts.
Thanks Denny for the photos. It sure helps to see something
rather than reading about it. Yes, a picture is worth a thousand
words..... especially true with these old trucks.
Spot
Chuck
1941 Chevy coupe
Spotbiltxo #464938 10/26/2008 2:35 AM
Apparently the previous owner had reason to use the holes for bolts, as they *do* go through the sheet metal on the grill, so the bolts are actually helping to hold it up.
I took a razor blade and sliced off the nibbles on the bumpers and then glued all 4 on the area above the grill where the hood meets using Loctite glue. Worked like a charm.
Spot
Chuck
1941 Chevy coupe
Well, you pulled my fat out of the fire yet again! Thanks for the hood bumper photos. Couldn't have done it without you.
Finally '54
gotta use the photos when I do mine too.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
