1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I have a spare oil pan from the flood motor and they have a pin hole in the bottom id the sump area. Can you weld up asteel oil spans? Pros - Cons? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Steel pan should weld up fine use a Mig or Tig and get everything as clean as possible. Concerns may be is the pinhole from damage or corrosion? If corrosion you may have more than just a pinhole once you strike an arc on it. One sure fire way to make a repair is make a small patch and weld over the hole. This should get you to good metal and prevent further opening of the already damaged area. Before you reinstall fill the pan with water and let it sit for a period of time to see if the repair took, any signs of weeping indicate you missed something. | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I have had good luck with JB Weld for pin holes. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I like to wire weld a patch on something like that. If you have rusted thin metal, you will know it because you will do nothing but burn the hole bigger. But at least then you know you are working with junk. I use diesel to test something like that. It finds smaller holes, and leaves a trail easier to find than water.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have had good luck with brazing holes with a flux coated rod. Clean it up good and take your time.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | The oil pan that came with my 292 had a connecting rod thrown though it some time in its past. A PO had brazed, stick welded and used JB weld on it along with some misplaced hammer blows.
Do you know how hard it is to find a 292 oil pan ? I watched EvilBay for 6 months before snagging one. Now if I could only find a PS set-up. | | |
