0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#463587 10/21/2008 2:08 PM
I have a spare oil pan from the flood motor and they have a pin hole in the bottom id the sump area. Can you weld up asteel oil spans? Pros - Cons?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Steel pan should weld up fine use a Mig or Tig and get everything as clean as possible. Concerns may be is the pinhole from damage or corrosion? If corrosion you may have more than just a pinhole once you strike an arc on it. One sure fire way to make a repair is make a small patch and weld over the hole. This should get you to good metal and prevent further opening of the already damaged area. Before you reinstall fill the pan with water and let it sit for a period of time to see if the repair took, any signs of weeping indicate you missed something.
I have had good luck with JB Weld for pin holes.
1949 Chevy 6400
1931 Chevy Firetruck
#463641 10/21/2008 5:58 PM
I like to wire weld a patch on something like that. If you have rusted thin metal, you will know it because you will do nothing but burn the hole bigger. But at least then you know you are working with junk. I use diesel to test something like that. It finds smaller holes, and leaves a trail easier to find than water.
I have had good luck with brazing holes with a flux coated rod. Clean it up good and take your time.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
gtow69 #464419 10/24/2008 12:37 AM
The oil pan that came with my 292 had a connecting rod thrown though it some time in its past. A PO had brazed, stick welded and used JB weld on it along with some misplaced hammer blows.
Do you know how hard it is to find a 292 oil pan ? I watched EvilBay for 6 months before snagging one. Now if I could only find a PS set-up.
http://community.webshots.com/user/49chevyman?vhost=community
"The only people who do not make mistakes, are people who do not do anything."
