1 members (Steelonsteel),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | OK...
sometime ago I was talking about getting some of these rusted phillips screws out, and somebody was recommending a tool that you'd hit with a hammer and it would turn with the impact of the hammer.
anybody know where I can get one of these bad boys? | | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | go to any parts dept or wall mart and ask for an "impact wrench"- they'll show you where it is. May even hold yer hand.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you ask for an impact wrench, they will take you to the air tool dept. Ask for an impact driver for screws. I thought coke would take care of that rust.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | thanks guys... found this at sears.com ; Sears Item #00947762000. search for impact driver and they have 3 different sets for anybody interested. Picture | | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | just ordered this one from northern tool and equipment . sears cheapest was $19.99, and I got this one from northern for $8.99. Picture | | | | | Joined: Jan 2002 Posts: 14 Member | | Member Joined: Jan 2002 Posts: 14 | Don't get a cheap chinese one! They are just JUNK!
The best kind would be a snap-on impact driver. (Hint: go on ebay and find a snap-on one for 30-40 bux). Otherwise go to sears and get one, but don't get a chinese POS!
Jay | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I've been using a Chinese made impact driver since the mid-70s when I bought a cheap set in Britain. If mine ever breaks, I'd replace it with this one, which is most likely made in China. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I seem to remember someone a few months, years ago rigged up an impact driver from an old extension. They welded a handle on the extension and a screw drive tip on the end of the extension. They put it their impact wrench and removed rusted in screws and bolts. They said it worked great. Maybe someone with a better memory could elaborate.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | There is two spray rust inhibitors that I will recommend here to the Bolters and I have had excellent results with them in eating away rust. I removed most of my screws on sheetmetal with a screwdriver or 1/4 drive socket. You must let it soak for a few minutes to up to 24 hours depending on how bad it is rusted. 1. PB Blaster by B'Laster/B.C.C.I. Cleveland Ohio 2. LPS #3 LPS Labs.Inc. Tucker Ga. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have an impact driver from Sears. And yeah its a Craftsman,I bought it back in the 60s and it still works just fine.Its one of those tools which has been used a lot and also loaned out on many occasions.Cant remember what I paid for it,probably around $20. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I have one also and find it indispensable for loosening Phillips head screws/bolts on old motorcycles. The issue there seems not to be rust, but the loctite makes it difficult to remove the screws without destroying the relatively soft heads. I would agree with the other posters, it is a great tool to have. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | answer for Larry .... works great, especially if you have lots to do  Bill | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | I got one of the chesp one's and broke the bits after a few screws, just got new bits off Snap-on truck and problem solved.
You Learn more Listening than Talking
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | red58, Thanks, I thought I was on the right track. Didn't remember it was an air chisel. It's still on the back burner, as I'm on the left coast. 8-]
Larry
