2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
OK...
sometime ago I was talking about getting some of these rusted phillips screws out, and somebody was recommending a tool that you'd hit with a hammer and it would turn with the impact of the hammer.
anybody know where I can get one of these bad boys?
May the force be with you - SoloWookie
solowookie.com
Oly Offline
go to any parts dept or wall mart and ask for an "impact wrench"- they'll show you where it is. May even hold yer hand.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
If you ask for an impact wrench, they will take you to the air tool dept. Ask for an impact driver for screws. I thought coke would take care of that rust. wink
Fred
52 3600
69 C-10
thanks guys... grin
found this at sears.com ; Sears Item #00947762000. search for impact driver and they have 3 different sets for anybody interested.
solowookie.com
just ordered this one from northern tool and equipment . sears cheapest was $19.99, and I got this one from northern for $8.99.
solowookie.com
Don't get a cheap chinese one! They are just JUNK!
The best kind would be a snap-on impact driver. (Hint: go on ebay and find a snap-on one for 30-40 bux). Otherwise go to sears and get one, but don't get a chinese POS!
Jay
People don't understand why I love old trucks...could it be cause i'm 17?
'54 3800 dually
http://www.dpsolutions-inc.com/54truck/truck.jpg
'56 GMC Dump Truck (and story)
http://www.dpsolutions-inc.com/56dump
I've been using a Chinese made impact driver since the mid-70s when I bought a cheap set in Britain.
If mine ever breaks, I'd replace it with this one, which is most likely made in China.
I seem to remember someone a few months, years ago rigged up an impact driver from an old extension. They welded a handle on the extension and a screw drive tip on the end of the extension. They put it their impact wrench and removed rusted in screws and bolts. They said it worked great. Maybe someone with a better memory could elaborate.
Larry
I don't own a vehicle that isn't old enough to drink.
There is two spray rust inhibitors that I will recommend here to the Bolters and I have had excellent results with them in eating away rust. I removed most of my screws on sheetmetal with a screwdriver or 1/4 drive socket. You must let it soak for a few minutes to up to 24 hours depending on how bad it is rusted.
1. PB Blaster by B'Laster/B.C.C.I. Cleveland Ohio
2. LPS #3 LPS Labs.Inc. Tucker Ga.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
I have an impact driver from Sears. And yeah its a Craftsman,I bought it back in the 60s and it still works just fine.Its one of those tools which has been used a lot and also loaned out on many occasions.Cant remember what I paid for it,probably around $20.
I have one also and find it indispensable for loosening Phillips head screws/bolts on old motorcycles. The issue there seems not to be rust, but the loctite makes it difficult to remove the screws without destroying the relatively soft heads. I would agree with the other posters, it is a great tool to have.
answer for Larry .... works great, especially if you have lots to do grin
I got one of the chesp one's and broke the bits after a few screws, just got new bits off Snap-on truck and problem solved.
You Learn more Listening than Talking
Bill Burmeister
red58, Thanks, I thought I was on the right track. Didn't remember it was an air chisel. It's still on the back burner, as I'm on the left coast. 8-]
Larry
Moderated by  MNSmith
