1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
Does the brake shoe holddown spring with the small coil on one end go on the primary or secondary shoe? This is for a 1967 C20.
Joe
'67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor
"Tighten until the stud snaps, then back off half a turn."
Since I have no experience with a C20 I probably should keep my mouth shut on this one....but, my experience has been that both shoes have always had a hold down spring on them.
OK, now the pro's can jump in on this one.
Riding in the Passing Lane
You are right Chipmunk. With self adjusting brakes the front shoe often has taper spring. The secondary shoe Has the bracket under it & has a cup that the spring goes into.
1972 Chevy c10 Cheyenne Super
So the tapered spring goes on the primary shoe. Thanks for clearing this up for me.
Joe
Had to think a bit on that one but yep that is correct. there is often a small thin flat washer that goes under that spring.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
