2 members (MikeStone1953, Guitplayer), 53 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
#45980 06/07/2005 4:04 AM
ODSS Lawman
ODSS Lawman
I am wrapping up my dual carb, Fenton 261....
I purchased 4" air cleaners for the carbs and all over the box it reads "not for highway use"
Should I use these or not???
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#45981 06/07/2005 4:23 AM
Sounds like one of those CYA discalimers from here. We say this but you and thousands like you disregard it and thank heavens for that or we'd be out of business...... BS prevails boys and girls......
#45982 06/07/2005 9:19 PM
I don't believe that they flow enought air. There have been several post's about this but it has been a while. Do a search here.
#45983 06/08/2005 6:00 PM
51green,
What 4" air cleaners did you use.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#45984 06/09/2005 7:28 PM
ODSS Lawman
ODSS Lawman
They are 4" chrome air cleaners from Mr. Gasket
Here is the exact part...
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=MRG&mfrpartnumber=4354
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#45985 06/09/2005 9:24 PM
If you are concerned, go to an auto parts store and look thru the filters for a taller element that will fit the chrome. It will make a huge difference.
How did all this sawdust get under the hood?
#45986 06/09/2005 9:37 PM
Sweet;
I still have one of those 4" jobs on my 261 that I bought from K&N. Does a fine job and no problem with insufficient airflow as far as I know. When I do my rebuild, I'm putting on two 2bbl Holleys with chrome spun air cleaners I got from Tom Langdon. I'll volunteer my one 4" one to you for free if you'd like. At least one would be sucking good for sure.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#45987 06/11/2005 9:16 PM
I used one of those on my 250 with large bore monojet; 16 mpg, more power then stock carb and filter, and no problems.
Boo
We don't need no stinking V-8s!!
#45988 06/12/2005 7:01 AM
Those ought to flow plenty of air.If you still have doubts,you probably have room under the hood to stack two elements per filter.If clearance is questionable,get a paper cup and cut it to the same height as the element and set it on the air filter you think is closest to hitting the hood,then close the hood. If it doesn't smash the cuo,you're good to go. Brush a little gorilla snot on between the elements and let it cure a couple of minutes before you install them on the carbs.That keeps them from trying to slip sideways or leak between them. I have also used a slice of big diameter heat shrink about 3/4 inch wide to hold 'em together,but Haven't had any of that stuff since I left the mine job,years ago.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
