2 members (RLB, Patina 54),
98
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,426 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45948 06/06/2005 10:54 PM | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | Im tired of worrying about potentially catastrophic failure of my old school single master cylinder. Is there any way to swap in a more modern dual master cylinder? Surely someone has encountered this before? any info would be much appreciated!
thanks! | | |
#45949 06/06/2005 11:17 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | ecihotrodbrakes.com
edit: sorry I mistyped. | | |
#45950 06/06/2005 11:28 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Search for master cylinder. There are a ton of posts about the swap.
jay
Your lack of preparation is not my emergency
#45951 06/07/2005 4:24 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 |
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#45952 06/07/2005 4:44 AM | | Anonymous Unregistered | | Anonymous Unregistered | When did dual master cylinders become stock? | | |
#45953 06/07/2005 2:23 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 1967 on all cars & light trucks wen,t to dual master cylinders. It was a government regulation. A few had it before that. Rambler pioneered it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#45954 06/07/2005 2:58 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I went throught the same thing with a '39 Packard several years ago for the same reason. Be very careful which size master cylinder piston size you choose. Bigger than 1" will not stop you with drum brakes. Pistons >1" are for disc systems. It will take some looking around for a 3/4" to 7/8" master cylinder that has the deep hole for a long rod (manual) versus the short rod used on booster type systems. Hope this helps.
#45955 06/07/2005 8:56 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | 6cylindersovertexas,
I just went to buy a bracket the other day and the kid that answered the phone at mpbrakes says they do not have a bracket that fits AD trucks and allows you to keep your clutch. He said you can only use their stuff with an automatic. I am pretty sure they had the bracket at one time.
I have dealt with ECI before, but they raised there prices a bunch and I tried shopping around. Ended up with the ECI bracket cause even at the increased price its a lot easier than the time it takes to weld one up and the guys there know their stuff. They are way overpriced on their master cylinder and residual valve, too IMO.
Chris | | |
#45956 06/08/2005 4:48 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | MP Brakes doesn't have an adapter bracket, but Chevy Duty does. You can buy the bracket from Chevy Duty and go to MP Brakes for the approiate master cylinder. www.chevyduty.com/frame-store.html It's a good looking bracket and I used the basic design to come up with a bracket for my 37. Not finished with that project yet, but it's coming along nicely. I bought a Master Cylinder from MP Brakes and had them set it up for the lines to come in on the opposite side from stock to keep them away from the transmission. It's going to work great!
#45957 06/08/2005 1:20 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Picture looks just like the ECI one, for $10 more than ECI. These brackets used to be $69.95 everywhere I looked. Mine came last night via UPS from ECI. What I like about it is that it is bent with a sheetmetal brake and then welded using only one piece of metal, if I had to make it myself, I would have a lot more welds.
Would love some pics of your 37 setup as I brought a 39 home last night and am thinking a dual master for it, too since I have to check all the wheel cylinders.
Olivertwisto, if you want a picture of this thing so you can get your creative juices flowing let me know. I can probably take a pic with it in the 53, too since theengine and tranny are out right now.
Chris | | |
#45958 06/08/2005 5:11 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Classic Performance is another source for the dual MC upgrade. http://www.classicperform.com/ 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#45959 08/17/2005 4:06 AM | Joined: Apr 2005 Posts: 31 Junior Member | | Junior Member Joined: Apr 2005 Posts: 31 | anyone have the details as to what dual master cylinder is being sold/used by jim carter's and chevy duty??
I saw the posts of custom car companies,...however, i'm not into billet parts for my truck. thanks in advance
Jason | | |
#45960 08/17/2005 12:54 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | So can a dual master cylinder kit be used in an AD truck with a manual transmission?
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#45961 08/18/2005 1:31 AM | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | I've got to ask the same question again. I have asked it in the past but have never got a real decicieve ? answer. Can it be done??? | | |
#45962 08/18/2005 3:20 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've never used a "kit" but my truck has a dual res master with a vacuum booster and it's all under the floor. I made my own mounting bracket, mounted the booster and master to it, made an adjustable link to the pedal and replumbed it. Scott | | |
#45963 08/18/2005 5:35 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I bought the bracket from ChevyDuty, though I learned soon afterward that the same part was available cheaper from Classic Performance.
I converted to front disks at the same time, and used a power brake master from a '73 Chevelle, but without the booster.
I had some trouble with the brake and clutch pedals, but solved it by spacing the brake pivot a little further from the clutch pedal. At first I didn't like the solution, but now almost three years and 10,000 miles later I'm satisfied it did the job.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#45964 08/18/2005 8:21 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | The kit I've got from CPP came with a spacer for the brake/clutch pedals.
The problem with booster/master cylinder on a manual transmission is that both of them together are longer than the original 4-spd or 3-spd. So, if you are using either of the original manual transmissions the rear transmission cross member prevents the use of both a booster and master. If yer using a t-5 or have put in an automatic of some sort you will have had to have either removed or relocated that cross member.
I know lots of people who run just manual brakes. I'm putting a booster in mine 'cause I've got the space and time.
