| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45915 06/06/2005 5:41 AM | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | I was cleaning up the distributor and came across a little screw cap below the base of the head. I unscrewed it and found another screw piece and then a spring. It was packed with grease. (Hope this discribes it well enough) I figured this was for lubricating the distributor shaft. Is that it? | | |
#45916 06/06/2005 7:19 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Yep-thats it. You pack it once or twice a year,and when you do a tune up or maybe once a month if you drive it a lot,give it a twist,half a turn or so. Some had an oil cup instead,then,for no apparent reason,they decided the distributor didn't need to be lubed. That's why you can get replacement distributors from all the parts stores now-they wear out now. | | |
#45917 06/08/2005 1:01 AM | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | Thanks speed, I thought that was it. I packed it and it's ready to go! | | |
#45918 06/08/2005 3:35 AM | | Anonymous Unregistered | | Anonymous Unregistered | What kind of grease do you put in it? thanks | | |
