2 members (Wally / Montana, TooMany2count), 32 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#45915 06/06/2005 5:41 AM
I was cleaning up the distributor and came across a little screw cap below the base of the head. I unscrewed it and found another screw piece and then a spring. It was packed with grease. (Hope this discribes it well enough)
I figured this was for lubricating the distributor shaft.
Is that it?
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
#45916 06/06/2005 7:19 AM
Yep-thats it. You pack it once or twice a year,and when you do a tune up or maybe once a month if you drive it a lot,give it a twist,half a turn or so. Some had an oil cup instead,then,for no apparent reason,they decided the distributor didn't need to be lubed. That's why you can get replacement distributors from all the parts stores now-they wear out now.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#45917 06/08/2005 1:01 AM
Thanks speed, I thought that was it.
I packed it and it's ready to go!
Regards, Kevin
#45918 06/08/2005 3:35 AM
Anonymous
Unregistered
Anonymous
Unregistered
What kind of grease do you put in it? thanks
