| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45833 06/03/2005 4:31 PM | Joined: Jul 2003 Posts: 10 Junior Member | | Junior Member Joined: Jul 2003 Posts: 10 | I'm getting ready to put together my 261 "Cadillac 6" I got from Tom Langdon. I bought an Offy dual intake and noticed the inside diameter seems small. I thought I saw a post that said there is a difference between a 216 manifold and the 235-261 manifold. I thought the post said the 216 had a slightly smaller inside diameter. Is anyone aware of this? Thank you. | | |
#45834 06/03/2005 6:08 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I assume you are talking about the ports on the intake. The 216 ports are smaller. You have two choices to fix that. 1.) You can have a machine shop enlarge the ports so they match the head ports and accept the 235-261 alignment rings. 2.) You can call Steve at Buffalo Enterprises - phone number: (360).652.7684 and I believe he sells alignment ring adapter-reducers. By the way, I like your Stovebolt name!!  I hope no one gets us confused!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#45835 06/03/2005 7:02 PM | Joined: Jan 2004 Posts: 41 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 41 | 6CYLINDER,
Third choice: if you bought it new and recently, get it exchanged. Might have been the result of dyslexia (216/261).
Otherwise, 6cylinderovertexas gave good advice.
Let's play together nicely.
#45836 06/03/2005 8:09 PM | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | 6cylinder:
IF you bought the Offy from The Stovebolt engine company, I had the same problem. They weld in the plugs on the underside of the manifold and sometimes they get put in the wrong box. Give Tom a call and he will ask for some dimensions. If you have the wrong one, he will send the right one quickly.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
#45837 06/04/2005 12:59 AM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | 216 manifold will have 1-7/16" (1.437) ports, 235/261 manifold will have 1-17/32" (1.531) ports. Same spacing port to port. 216 manifold will take the small base carbs, 235 will take the big bases. 2 of the bolts on the 4 bolt pattern where they bolt to the exhaust manifold (if not using headers) are different spacing. My favorite is to use the 216 manifold for the small base carbs and bore the ports to take the 235 alignment rings. | | |
#45838 06/04/2005 9:13 PM | Joined: Jul 2003 Posts: 10 Junior Member | | Junior Member Joined: Jul 2003 Posts: 10 | Thanks for the info. I called Tom Langdon and verified that I did have a 216 manifold. I bought it new from Egge Machine Co. last Oct. Hopefully, they will take it back and exchange it for the 261. | | |
