0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45655 06/01/2005 4:52 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | I have a 216 in my '52 half ton, I am not able to rebuild the engine myself so will have to bring it to a shop. This is going to be an expensive job so I'm hoping you guys can help me with determining just how much of a rebuild it needs. Here's the story, it runs very well and starts up nicely everytime, however, it smokes so bad I cant take it anywhere that it would have to idle in traffic. I have done a compression test and found 5 cylinders have approxiamately the same compression and 1 without any. I did a leak down test and found the compression went up a little on the bad cylinder which I'm told is an indication that the ring is bad on that cylinder. Also, I have oil leaks from a few spots underneath, but nothing so bad that adding a little oil once per season doesnt handle.
So, I'm looking at gaskets and the ring on cylinder #5. When I go to a shop to talk to them about it where do I start in terms of what I need them to do. It would be great to have a complete rebuild but if I cant afford it is there a more affordable route I can take? | | |
#45656 06/01/2005 5:00 PM | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | rings should be done in a set, do all six while your there.
if they can just hone the cylinders for you (if they don't need to be bored to clean up the walls or they are out of round)
then re-ring the pistons, and replace the bearings and gaskets, and be on your way.
2003 ford lightning 1959 chevy 36
#45657 06/01/2005 5:12 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Well, I agree with the re-ring and gaskets, but the 216 doesn't have replacable rod bearings (unless it has already been converted). Check the clearance, and remove shims as needed. Oh, yeah, and be careful to note how many and where the shims are located.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#45658 06/01/2005 7:30 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | You should get a shop manual for your truck. With the guidance of the book and this board you should be able to re-ring and hone it yourself and save your money for other parts.(Plus the satisfaction you'll get doing it yourself) If you take it apart and the cylinders are scored make a boat anchor out of it and look for a 235 or a 261 which will drop in with minor modifications. Rings might just be stuck in the piston grooves on your dead cylinder. What if there's a sweet running motor in your neighborhood for a couple hundred bucks that you overlooked? No sense on blowing $1000 + to rebuild yours in that case. Just my opinion...
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#45659 06/01/2005 10:52 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | I agree with the upgrade in motor, one with full oil presure, 235, 250. There is a 1965 250 with a fourspeed tranny in our local thrifty nickel for $250. It runs and doesn't smoke. If I hadn't just bought a 72 4 speed tranny I would have opted for this setup, and I have a 235 in my truck already. And another 235 motor that doesn't smoke for $150.00. Can't beat those prices. I know you are far away and it would cost you $500 to ship a motor that far. If you have time search your local thrift papers or junk yards.
Dan Dilts Woodland Park, CO
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough! 53 5window 1/2 ton54 3window 1/2 ton
