3 members (Nick in Manitou, Wally / Montana, 1 invisible), 58 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
I have a 52 3100 I had just converted from a closed driveline to an open driveline. The pinion seal on the replacement rearend is leaking. NAPA lists three different possible rears for the year rearend I had installed which is between 54-59. How can I tell which rearend it is and can I replace the seal myself. Do I just remove the driveshaft, the the big nut, pop out the seal and install the new one? Is it that simple?
Any help is much appreciated.
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
Riding in the Passing Lane
It is almost that simple. After removeing the drive shaft mark the shaft & nut so they can be tightened back where it was. Remove the nut. A hammer will probably remove the flange but you may need a puller. Then dig the seal out. You can probably find a number & brand on the old seal & the parts store can cross it over if its a different brand then what they handle. If not they can match it up by dementions.
1972 Chevy c10 Cheyenne Super
