| | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | I have a 52 3100 I had just converted from a closed driveline to an open driveline. The pinion seal on the replacement rearend is leaking. NAPA lists three different possible rears for the year rearend I had installed which is between 54-59. How can I tell which rearend it is and can I replace the seal myself. Do I just remove the driveshaft, the the big nut, pop out the seal and install the new one? Is it that simple?
Any help is much appreciated. Thanks
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is almost that simple. After removeing the drive shaft mark the shaft & nut so they can be tightened back where it was. Remove the nut. A hammer will probably remove the flange but you may need a puller. Then dig the seal out. You can probably find a number & brand on the old seal & the parts store can cross it over if its a different brand then what they handle. If not they can match it up by dementions. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
