5 members (UtahYork, 1955 1 Series, greenie-reddy, dt235sd, klhansen), 210 guests, and 1 robot.
Topics128,085
Posts1,055,969
Members48,430
Just installed a new choke knob and cable on my '49 but am having trouble getting the cable to work right. I'm probably doing something wrong or forgeting something but the cable wants to twist and open the choke even with the knob in all the way. And when I tighten down the choke cable to the choke lever on the carb it just pulls on the outer casing of the cable and not the wire. If you can, look at the pics and please let me know what I can do differently. Thanks for the help!
http://i245.photobucket.com/albums/gg53/sapo_trucker/P9210539.jpg
http://i245.photobucket.com/albums/gg53/sapo_trucker/paintchokelinkage.jpg
Riding in the Passing Lane
That carb was designed for an automatic choke. Any thing you do will be inprovising. Ive never seen one hooked up like that. Usually you mount the caseing in a stationary bracket & the core pulls on the lever.
1972 Chevy c10 Cheyenne Super
I had given up on using the heat coil from the manifold for the choke cause it isn't very smooth at all (the coil is probably rusted up).
This would probably work right, if I could make a bracket to hold the casing in place?
lazy j
wrenchbender has it right. You need to mount the casing into a stationary mount.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Lazy J.
Give the pictures a peak on my fliker link. Look at the carb mock up set. There is a picture of my manual choke setup.
Hope it helps.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Thanks "cavebull" that helps! I'll just have to fab up a little bracket to hold the casing then. That should all the problems. Thanks again guys!
