| | | Forums66 Topics128,094 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | Just installed a new choke knob and cable on my '49 but am having trouble getting the cable to work right. I'm probably doing something wrong or forgeting something but the cable wants to twist and open the choke even with the knob in all the way. And when I tighten down the choke cable to the choke lever on the carb it just pulls on the outer casing of the cable and not the wire. If you can, look at the pics and please let me know what I can do differently. Thanks for the help! http://i245.photobucket.com/albums/gg53/sapo_trucker/P9210539.jpghttp://i245.photobucket.com/albums/gg53/sapo_trucker/paintchokelinkage.jpg | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That carb was designed for an automatic choke. Any thing you do will be inprovising. Ive never seen one hooked up like that. Usually you mount the caseing in a stationary bracket & the core pulls on the lever. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | I had given up on using the heat coil from the manifold for the choke cause it isn't very smooth at all (the coil is probably rusted up). This would probably work right, if I could make a bracket to hold the casing in place? | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | lazy j wrenchbender has it right. You need to mount the casing into a stationary mount.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Lazy J. Give the pictures a peak on my fliker link. Look at the carb mock up set. There is a picture of my manual choke setup. Hope it helps. Cavebull | | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | Thanks "cavebull" that helps! I'll just have to fab up a little bracket to hold the casing then. That should all the problems. Thanks again guys! | | |
