1 members (Eisenholtz), 59 guests, and 3 robots.
Topics128,022
Posts1,055,377
Members48,422
#454484 09/21/2008 4:52 AM
Need to pull the transmission to install new motor. I have got everything but the stick and two bell housing bolts disconnected and ready to go. Now how in the :mad: &%#@! do I get the #$@%! stick out ohwell ? I thought is was a single pin, but now realize that it is two. Can any body help? This is on a 1965 K10. Thanks in advance.
Give me my Truck, or...my truck daamit! Cause i aint leavin without it!
http://picasaweb.google.com/jadefalcon1218/MyK10
If it's a four speed, just push down on the tin cover covering the round part of the shifter and turn counter clock wise. Do not try to remove any pins, it's not that complicated, LOL,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks, 48bigtrucks. Feel about as smart as a turnip after finding out it was that easy! blush Not only was your response about as fast as a jack rabbit, it saved me an entire night of frustration! headscratch Many thanks.
