| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | I tried to remove the parking light to rewire them as turn signals. Once I unscrewed the chrome I could not get it out from under the grill. Is there a trick to removing the parking light and lense or is my truck unusual. I thought I could just unscrew it and unscrew the lense and they would come out but there tucked under the grill and very tight. Any suggestions? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | TPB, On mine I had to loosen up some of the bolts holding the grill close to the parking lights and a few of the bolts in the cross bars to get some flex, so I could get mine out and in without damaging anything. Tim | | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | Do you use your parking lights as turn signals? It also seems like all the wires are hiddern behind the inner fender.This little job has suddenly turned in to a pain in the tush. | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | If you remove the two nuts that hold the housing to the grill, you should be able to rotate the housing and wiggle it out without scratching anything.
In order to make them into turn signals, you need to remove the bulb socket and install a double pigtail and buy a dual filament bulb.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
