Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (KingG, Joe H, Lightholder's Dad), 42 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#454136 09/19/2008 8:14 PM
Well i am off for the weekend to go pick at my trucks. but before I leave i hope someone can answer my question. At one time someone got carried away with spraying undercoating on my frame and pretty much everywhere else. I need to clean this stuff off, and what I have done so far is a pain. I am using an angle grinder and a wire wheel. which seems to just move it around, and mostly on to me. Is there a better way? can you burn that S**t off?
Ex Hall Monitor
Ex Hall Monitor
This might help. Google is your friend. smile
Tiny #454211 09/19/2008 10:38 PM
I have some luck with an electric heat gun, looks like a heavy duty hairdrier, and a putty knife or gasket scraper. Torches are too hot and fire is a problem you don't really need.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #454346 09/20/2008 2:55 PM
That and you don't want to burn that stuff... Many types can form a caustic acid when burned that can eat your frame alive...
-Matt
easy off oven cleaner maybe
that came to mind
don't know, it's just a thought
Jim & Caroline
I've been working on a '50 Chev that was undercoated when it was new. I've had good luck using carb cleaner spray. I spray the area that I want to work on with the carb spray and let it soak for a few minutes, then take a screwdriver or scrapper and it will come off and expose nice clean metal. I've found that once you get a small spot cleaned off, then spray the edges so the carb cleaner can work its way in it helps. I've had great luck, getting brake lines off, brake hoses, backing plates, splash shields ect. The bottom line is it takes time and patience to do a good job, and its messy no matter what method you use.
Don
