8 members (Hotrod Lincoln, sudsyz, Chip O, Gdads51, 1955 1 Series, stlcardinalsguy, tclederman, 1 invisible),
67
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | when you guys put dual carbs on how much work did you do to the internals of the engine? I have a 235 but I know I want dual exhaust, nothing sounds cooler!!! but the dual single carbs I never really considered until I saw how cool they look. does it wake the motor up quite a bit when you do that? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | rusty52stovey,
IMHO...two carburetors will work fine with an almost stock engine. To get the most out of the 'in' improvement, a corresponding 'out' modification works well. This means some headers and dual exhaust. Another bolt on that finishes the picture out would be some type of high energy ignition or solid state ignition.
These are about all you can tack onto your engine without going inside and doing major work. The dual carbs, dual exhaust and fancy ignition wake it up to a noticeable degree and it all looks good to boot.
Stuart | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have dual carbs on mine and it did some good when i put them on but not a lot. and i do believe they use more fuel. now i have upgraded to fenton headers and t-5 trans 2.73 rearend hei distributor and other things and to get the most out of all that they are necessary. just my opinion. romn
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | Ok next question were can you get this stuff? intake and HEI for the 235? I did see one intake it was somewhere but it wasn't all chromed like most of those guys intakes | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Ive heard from a few guys on the oldgmctrucks website that reported better fuel mileage when running dual carbs. I cant remember if I read that here as well... Check out the links section. Theres a bunch of good vendors that sell all sorts of parts. I prefer these guys for most of my stuff; Chevs of the 40sJim CartersThe Filling Station | | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | OOOOOOOOOOOOOOOOh shiney offy intakes and oh wow a triple carb set-up cool. I am like a kid in a candy store now | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The the inside carb/air cleaner on a triple-carb set-up might be tight against the firewall in a Chevrolet engine bay. Tom Langdon is a good source of parts and advice. http://www.stoveboltengineco.com/ | | | | | Joined: Aug 2007 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 116 | hey guys will a stock fuel pump be sufficient to supply fuel to dual 2 barrels on a 261?
http://www.flickr.com/photos/50657267@N08/sets/
1939 1/2 ton Resto-mod 1937 1 1/2 ton Is in the driveway
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Stock fuel pump will be more than adequate for a dual carb setup on any 216-261 setup. In fact, if you go with Langdon's dual Holley/Weber setup, you'll want to use a pressure regulator and drop it back to 3.5 psi.
I'm running a pair of Carter/Weber 2bbl carbs from Langdon's on a 235+ engine with 261 grind cam and performance and mileage is good. Installation is straightforward and after the initial synchronization, they have held their tune. Have pics in my Webshots of both the dual C/W and single H/W install.
Dave | | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | now running two carbs is that like running three deuces. it will run off of one until you kick it down. or do both carbs dump fuel in together? and are they hard to tune? I helped a guy with three deuces on a olds rocket motor and it sucked!!! | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | For a dual setup you would want them to work together to even out the distance from the carbs to the cylinders. With a triple you can use a center primary and secondary or dummy end carbs. It sounds like you already know where the challenge is going to be and syncronized carbs are only as good as their linkage. The shiny parts in the catalogs are reproductions of antique speed parts and the job of the “floating” linkage that comes with them was simply to hold both throttle plates vertical for racing. Making it idle smoothly is accomplished by bending the linkage and has been described by some as “poor at best”. If you can find a vintage intake with an integral throttle pivot rod it will work like a dream or if you like Tom Langdon’s setup he engineered a pivoting solution to work with the carbs he sells. Here’s some intake pic’s: http://www.jalopyjournal.com/forum/showthread.php?t=200740&showall=1And here’s some info on choosing O/E type carbs: http://www.thecarburetorshop.com/RochestermultipleB.htmHave fun.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
