0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 25 Apprentice | | Apprentice Joined: Apr 2005 Posts: 25 | After my truck sets for about 3 days the GM 350 trans begins to leak. It leaks about 1 quart per week. The oil appears to be coming from the fill pipe or the downshift cable. I was told tha torque converter is leaking, overfilling the pan. Is the solution a new torque converter or a better seal at the fill pipe or cable? My trans has o-rings for seals at the pipe and cable. I have seen 350 trans with a boot for a seal at the fill pipe. Shuold I have a boot? Thanks in advance for any help with my prablem.
| | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | i have one that does the same thing and i put a new o ring in the fill tube and it still leaked so i finally just quit putting fluid in it because is was starting to slip ( they don't like to pull 20,000+ pounds behind a strong 400sbc) but anyways after about 6 months of me not adding fluid i filled it up and it doesn't leak anymore. you do check the fluid while it's hot right? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All trans. dump some of the fluid out of the converter when shut down. It shouldn't leak though. Replace the seals around the fill tube & cable should fix it. Some models use an O=ring & some use the boot type seal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
