5 members (Wheelie, Jay R, 1955 1 Series, Napco Man, WICruiser), 136 guests, and 2 robots.
Topics128,083
Posts1,056,080
Members48,434
#453819 09/18/2008 11:57 PM
Apprentice
Apprentice
1 Offline
After my truck sets for about 3 days the GM 350 trans begins to leak. It leaks about 1 quart per week. The oil appears to be coming from the fill pipe or the downshift cable. I was told tha torque converter is leaking, overfilling the pan. Is the solution a new torque converter or a better seal at the fill pipe or cable? My trans has o-rings for seals at the pipe and cable. I have seen 350 trans with a boot for a seal at the fill pipe. Shuold I have a boot?
Thanks in advance for any help with my prablem.
i have one that does the same thing and i put a new o ring in the fill tube and it still leaked so i finally just quit putting fluid in it because is was starting to slip ( they don't like to pull 20,000+ pounds behind a strong 400sbc) but anyways after about 6 months of me not adding fluid i filled it up and it doesn't leak anymore. you do check the fluid while it's hot right?
Riding in the Passing Lane
All trans. dump some of the fluid out of the converter when shut down. It shouldn't leak though. Replace the seals around the fill tube & cable should fix it. Some models use an O=ring & some use the boot type seal.
1972 Chevy c10 Cheyenne Super
