1 members (Robert Crandall),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,118 Posts1,056,646 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 28 | I read a bit here about chevy S-10 swaps for the AD trucks. IS this a convienience swap, opportunity at hand or cheap solutions?
Youngest son and I are off today to trailer a reportedly 51 home.
And there begins the questions. Where do we start?
I believe it may have a 235 in it. The list of missing parts has not been generated. Our basic idea is to make it a driver, not a show queen. I'd really like him to have a truck he can get around in for reasonable operational costs and simple maintenancece. He has no need for Interstate travel. I have no interest in paint, and limited welding, yet the posibility of finding a drive train to install is there, I'd be remiss to not tell you we're on a limited budget. We happen to have a few You-pull-it yards in our area, and a basic "a part that will do the job" is more likely than finding authentic parts. I recognize that gajillions of parts and remans are available, not to mention the number of antique yards available virtually.
I intend to have him register here and use it as a research tool. I'll likely be here doubly.
Check this?
SOAP-
Subjectively put together an overview
Objectively evaluate and list.
Assess the evaluation and work through the possibilites.
Plan on working down through your best approach derived from the above processes.
Get to work. Any changes to the PLAN, start with the "S"
If anyone would like to point me in a direction where I might find similar "canned" suggestions that are specific to truck restorations, please relay.
Did I mention that I find this site to be the BEST on the web?
Thanks, I wish I was bringing something to the table, but I have nothing to offer, and can only be sure of taking plenty away.
GeeVee | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Hope that your plans turn out OK. and by the way Welcome to the bolt. Enjoy on hearing about the father son projects at work so keep us posted, and we love pics. so take the camera and keep the memories | | | | | Joined: Jul 2008 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 28 | Thanks, been lurking here since I found the truck, mostly because I haven't been able to contribute any real help to anyone.
Now we're bringing it home.
Pictures are worth a million, and I'll have plenty. Using the pin the map link you have, just as I was asking for something similiar, up you pop.
Thanks.
GeeVee | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | You might want to have a look at this: http://www.ad-engineering.com/I've bought parts from him and he seems like an up-front guy. I have no experience with his conversion parts. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Mongo, a bolter on this site has a website here. That may give you some insight on what is required to successfully complete. Good fabrication and welding skills are a plus also. Have fun and good luck Dan | | | | | Joined: Jul 2008 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 28 | Thanks Czechman, that must have been what I'd read about in these pages....
Not my cup of tea. | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | let me tell you if you can not weld or have a friend that can weld and fabricate you do not want to do a s10 swap it is a lot of work dont know if the ad trucks are easer than the art deco but wow i have striped 2 s10 to bear frame and started to build a frame up 1942 chevy on a 93 s10 good thing my buddy works in a shop that repairs cranes he has made a lot of stuff for me and helped me out welding stuff up keep the 235 and if need be add a auto and late model rear and keep the orginal frame thay make a kit to do disk on your spendle worth the cost in my book if you let your sun drive it
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I've seen many with an S-10 frames on Craigs List..To me they always look like the bodies are too far off the frame..i.e. more space than normal between the tires and fenders...
Keith | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | GeeVee, These are the kits that I resell, I'll be happy to answer any questions you might have on the S-10 Swap. http://www.e-zchassisswaps.com If it's a good solid truck (the 51) and you can easily get it running/driving/stopping safely. I'd recommend adding 3 pt belts to it and getting him on the road. Other than the belts a brake upgrade would be top of my list as a dad. If you want to make it a hot rod project and build it up together the S-10 Route is a great low budget way to get to IFS, modern brakes, and a more modern drive train. To start one thing to consider (Like most old truck projects) is how good the body is, depending on what part of the country the truck is coming from and what kind of life it's had you can get into a lot of body work. A lot of people don't think of the safety factor of a cab with rotted out floors, kick panels and cab mounts. Even if you want a vintage looking patina on the truck I always recommend doing the necessary body work on the cab to get it solid. Back to the S-10 route. The goal of the kit we sell is to recycle as many pieces as possible from the donor truck (S-10) and save money in the process. The kit allows you to not just use the S-10 frame but to also the complete brakes system (right down to the pedal), steering column, accelerator pedal, wiring harness, and even the motor and transmission on 4.3 trucks. We include motor mounts for the 4.3 V6 and V8 Conversions as well as the transmission cross member and bracket to allow you to use the S-10 Column shift. Steve | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I'm interested more in using a S-10 driveline (4.3L) in my 47 1/2 ton. I've seen the odd post on this but can't seem to find much more on it. My frame is in good shape. I plan to update suspension, brakes etc. Does this driveline swap work? If so, is there anywhere I can be directed to for more information? Thanks.
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Rusty, On the 4.3 Swap, anything you read talking about a V8 Swap should be applicable to your stock frame. Your motor mounts will just set back further for the 4.3. I know guy's have done it. I was considering an S10 chassis that had a Later model Vortec 4.3 and 700R4 for my 47 1/2 Ton Project before the 87 S-10 chassis, and the 87 Firebird motor turned up. At this point my 47 is looking at a 40 year upgrade. I think the next one will likely be a 4.3 though. Now if you really want a cool 4.3 just look for a I6 261 it's almost 4.3 (4.27702 L).  Steve "Mongo" | | | | | Joined: Jul 2008 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 28 | I was just curious myself maybe about what Rusty mentions...
Thinking out loud. I'm just starting out here and don't know which direction is up.
Thnaks to all , checked the links. Kewl.
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Welcome to the Bolt GeeVee. You couldn't have picked a better sight to help you with your project. I used the IFS from a '79 on my '50. More Info here and also here. More photos available on my Webshots. Good luck!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Hi GeeVee,
It sounds like this may be one of your first projects, if so I would keep it simple. If you jump in too deep you may end up with an unfinished project, I speak from a lot personal experience here. My wife has finally figured out I have a truck to work on, not a truck to drive. First see if you can get it running and determine the mechanical condition of the engine. A running engine is a big motivator. If your son is planning on driving this truck on a regular basis do not skimp on the brakes. Rebuild the stock front end (king pins, spring shackles) and upgrade with a disc brake conversion kit. There are lot's of kits out there, Speedway Motors in Lincoln NE have some of the best prices. Add a dual resevoir master cylinder and rebuild the rear brakes. Now it should run and stop. If highway driving is a possibility you will find lot's of info here on a T-5 transmission upgrade and changing the rear axle to accomodate an open drive shaft. These changes will give you a truck that is capable of modern highway speeds, will stop a lot better, and is simple and reliable. Also as someone else mentioned, don't forget some 3 point seatbelts. Just my thoughts.
John | | | | | Joined: Jan 2007 Posts: 161 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 161 | these things always make me wonder: why oh why do so many people feel the need to change all that stuff? as Builder told me once "these trucks were actually made to drive". so make sure your essentials are good (that means: engine running good, brakes working properly, lights and horn working, your steering good, check your front end (king pins etc) and have it aligned) and that should be it. drive it! add some seat belts if you're concerned with safety (lap belts are $30). I drive mine anywhere, any distance. whether it's dirt roads or highway rush hour in Houston TX. that's my 2 cents. more fun, less cost | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | these things always make me wonder: why oh why do so many people feel the need to change all that stuff? as Builder told me once "these trucks were actually made to drive". You have a point but to each his own. I drove a stock '49 for awhile before I decided to update it with a V8, MMII suspension & Nova rear & disc brakes and I'll tell ya, for me the difference was like night & day!! My current project I've chosen to update as well but went a step furture by adding fuel injection and A/C. There are people meany people who choose to leave them stock but in the end, it's your truck so do what best suits you!
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | the new oct. 2008 custom classic trucks mag. has an article on using an s-10 chassis under a 53 stovebolt. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | My 47 runs well. The brakes are good but I'm going to replace the shoes, cylinders etc. I trust the truck, I don't trust the other guys zipping in and out with high powered imports and cutting me off. The motor starts and runs well but I get a little nervous that something that old might all of a sudden break. Updating can give some of us a little more piece of mind. It would be fine if everyone drove stock stovebolts around but, alas, that is not the case. But as mobilortho states,"To each his own."
