1 members (JW51),
115
0
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Well, I put my 235 in and started it. It had a terrible knock. So, I took it to the Midwest all truck national and let some guys listen to it. Everyone had a different opinion of it. It sounded like a rod to me. Well, I took it to the machine shop that built the motor and they pulled the pan, and much to mine and their delight. The noise was the rod bolt rubbing on the baffle in the pan. So, this could happen to you. It sounded terrible but became less noticeable as it rubbed the baffle down.
So to everyone that put an ear to my engine Thanks!!
Cory | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Hey cory,i took several pictures of your truck and engine.I didn't see you there this year.I love that engine in the 1954,glad you solved your problems. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Had a friend come over several years back,had a knock/tapping noise.So we open the hood,start it up and lo and behold the valve covers were wiggling.He had adjusted the valves and put em on backwards.This was an old chev 350.I've never seen that happen before or since! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I once had a freind that bought a really great old Buick Roadmaster straight 8 with a knock on the cheap. It was a bent crank pulley that was rubbing the timing tab and he saw it immediately. Unfortunately the former owner just knew it was a shot motor. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | had a fly wheel cover bolt to get lose once between the flywheel cover......boy talk about a racket at times...
glad you found where the probably was Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
