1 members (Cosmo), 76 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#451865 09/13/2008 2:21 AM
1 Offline
Well, I put my 235 in and started it. It had a terrible knock. So, I took it to the Midwest all truck national and let some guys listen to it. Everyone had a different opinion of it. It sounded like a rod to me. Well, I took it to the machine shop that built the motor and they pulled the pan, and much to mine and their delight. The noise was the rod bolt rubbing on the baffle in the pan. So, this could happen to you. It sounded terrible but became less noticeable as it rubbed the baffle down.
So to everyone that put an ear to my engine Thanks!!
Cory
1954 Chevy 3100
1952 Chevy Suburban
good catch cory
Jim & Caroline
Hey cory,i took several pictures of your truck and engine.I didn't see you there this year.I love that engine in the 1954,glad you solved your problems.
1951 3100 Chevrolet
Had a friend come over several years back,had a knock/tapping noise.So we open the hood,start it up and lo and behold the valve covers were wiggling.He had adjusted the valves and put em on backwards.This was an old chev 350.I've never seen that happen before or since!
I once had a freind that bought a really great old Buick Roadmaster straight 8 with a knock on the cheap. It was a bent crank pulley that was rubbing the timing tab and he saw it immediately. Unfortunately the former owner just knew it was a shot motor.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
had a fly wheel cover bolt to get lose once between the flywheel cover......boy talk about a racket at times...
glad you found where the probably was
Redryder pix
My Hotrod
