5 members (52Carl, GradyB, GRNHydra, Pre '68 Dave, DadsFirstPickup), 82 guests, and 1 robot.
Topics128,080
Posts1,055,944
Members48,430
#451925 09/13/2008 4:41 AM
has anyone installed a nice heater out of some late model that fits and works good, without a lot of modifiacation
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
I'm considering fitting a Heater from an Austin Mini (A rodders favourite) over here,it's a small self contained unit.This is on account of trying to get a decent heater core for my original unit. Mind you I don't think Mini heaters are thick on the ground in VA! My buddy in Newport News has one,but unfortunately he needs it for his '69 Mini!
I haven't quite got round to sizing things up,yet but my buddy had one in his '52 and it worked great!
I want to try and utilise the air intake on the right side of the cowl,which will involve a degree of fabrication. I don't think it'll be too much of a problem though!
Maybe someone else will 'chime' in with other suggestions?
More pix on Flickr.
I purchased and installed this unit.
www.ClassicParts.com
item # 68-991A
$159.95
While this unit does a fantastic job heating the cab there are a few things that arent right.
1-the fan is single switched ...either off or full blow
2-when ya close the doors on the unit for defrost the air volume that is pushed to the defrost vents is very lame , reminds me of the old VW Beatles.
So I would not recomend this unit for anyone living in the northern states and especially in the snow belt as i dont believe it will produce enough defrost to let you operate a daily driver in the dead of winter.
Tim
1952 Chevy Shortbed
Photos in Photobucket
There are some aftermarket heaters that Summit sells, and they may be worth a try. My stock heater only gets the cab lukewarm in the dead of winter, and my toes really get cold.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
