1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45166 09/03/2004 2:02 PM | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | I am getting about 10-12 mpg on my 61 Apache C20 with the 235 engine------is this about normal? It's all original with no modifications.
Not quite as lean Not quite as mean, but Still a Marine!
#45167 09/03/2004 3:13 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I got 11.7 MPG with my old 235 and 4.57 rear end. I haven't checked my 261 and 4.10 rear end yet. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#45168 09/03/2004 4:36 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | my 54 w/a 62 235 engine gets that kind of milage or worse. these old motors will run on about anything that will ignite but milage wasn't a concern back then.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#45169 09/03/2004 8:27 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I get about 16-18 with my 261 but only if I keep the timing advanced a few degrees. It's enough so it misses a little if you run the engine at fast idle (the vacuum advance kicked in) but at curb idle and under load it runs great. If I run it in the stock position I only get about 14. The engine is stock except for an auto choke rochester and a dual point distributor plate.
#45170 09/03/2004 10:01 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You don't check gas mileage on these old engines, you check oil mileage, Scott | | |
#45171 09/04/2004 3:07 AM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | hey, 10-12 isn't that bad-i was doing good to get 8 on my 61 K20. but, the six is gone now, and without the O2 sensor, the TBI 350 isn't getting much better. think i'm gonna work on that soon... | | |
#45172 09/04/2004 4:27 AM | | Anonymous Unregistered | | Anonymous Unregistered | Hey, have a '54 3800 panel(6800lbs emepty),17in. 750 12ply tires with stock 235 and a 4.10 rear end with a sm420 tranny. Took her on a 500 mile trip and averaged 9 miles a gallon and ONE quart of oil the whole trip. tony'n weatherford  | | |
#45173 09/04/2004 4:36 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Now I don't feel so bad getting around 14mpg in my, 62, 3/4 ton, long bed, stepside with a 235. I have gotten 17mpg in that truck but not since I had the motor rebuilt. I was hoping to get 20mpg. :•( Oh well, good thing I have a Honda that gets 40+mpg and a Harley that gets aroung 47mpg.
Speaking of gas: There are lots of stations here in N. TexAss running out of the stuff. Is a shortage in the offing?
delete my account and pictures
#45174 09/04/2004 4:43 AM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'm getting 20-22 freeway with my 235, T5, 3.55s Dennis
40 Chevy 1/2 ton
#45175 09/04/2004 2:22 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | My 51 with a stock 261 except for a Holley 2 bbl gets 21 MPG on the highway with OD.My 37,modified 261, again with OD, gets around 19 on the road. | | |
#45176 09/06/2004 1:52 AM | Joined: Feb 2004 Posts: 15 Junior Member | | Junior Member Joined: Feb 2004 Posts: 15 | Wow! I have a '46 Chevy 1/2-ton with a '57 235ci and I am getting 18-20 mph. But then my top speed is is only 48-50 mph! i am running radials instead of 6-ply with tubes. | | |
#45177 09/06/2004 9:40 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Since I have the dual Offy Holley/Weber setup I get 22 mpg at 65 mph out of a rebuild 235 on the Autobahn (freeway). Hope it is getting better with the overdrive I have waiting in the garage.
The gas is verry expensive in Germany A gallon is almost 3,60$ over here!
Frank | | |
#45178 09/07/2004 2:44 PM | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | I've driven on the Autobahn before-------if I tried to drive my 61 on the Autobahn we would be like one big speedbump!
#45179 09/07/2004 2:52 PM | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | For what its worth, Average MPG on our road trip from GA-CA and back was 12.6. 283V8 (.030 over) 3speed trans and 3.90 rear. Same as its done since 1976 on the road or in town.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
