Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Phak1, Tom McGrath), 119 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#4516 01/09/2005 9:59 PM
Hey all,
It's getting to be about time I quit slacking and try to fire my new 47 AD 216. I've changed the plugs, put in a bigger ground cable, and put a few drops of oil in each plug hole. Is there any reason, or method, to priming my fuel pump? Any help would definitely be appreciated.
jay
Your lack of preparation is not my emergency
#4517 01/09/2005 11:06 PM
Don't run it with old gas. If old run it off a hose from a little tank until you clean the gas tank.
54 3100 with 235
62 flatbed dump C60 with 261
#4518 01/09/2005 11:18 PM
I forgot to mention I drained the old gas. I'm gonna clean the end of my fuel line, and just dunk it into a can until I get my tank recondiotioned.
#4519 01/10/2005 1:28 AM
Loosen the pump attaching bolts about 1 1/2 turns each. Wobble the pump up and down until it's moving gas. If you're not sure, loosen the fuel line at the carburetor, and pump until it leaks.
#4520 01/10/2005 2:11 AM
Isn't there a bowl vent you could fill the carb with a cyringe (sp?) like the Quads have?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
