6 members (TexasJim50, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible), 56 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#45166 09/03/2004 2:02 PM
I am getting about 10-12 mpg on my 61 Apache C20 with the 235 engine------is this about normal? It's all original with no modifications.
Not quite as lean
Not quite as mean, but
Still a Marine!
#45167 09/03/2004 3:13 PM
I got 11.7 MPG with my old 235 and 4.57 rear end. I haven't checked my 261 and 4.10 rear end yet.
#45168 09/03/2004 4:36 PM
my 54 w/a 62 235 engine gets that kind of milage or worse. these old motors will run on about anything that will ignite but milage wasn't a concern back then.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#45169 09/03/2004 8:27 PM
I get about 16-18 with my 261 but only if I keep the timing advanced a few degrees. It's enough so it misses a little if you run the engine at fast idle (the vacuum advance kicked in) but at curb idle and under load it runs great.
If I run it in the stock position I only get about 14. The engine is stock except for an auto choke rochester and a dual point distributor plate.
Paint & Body Shop moderator
#45170 09/03/2004 10:01 PM
You don't check gas mileage on these old engines, you check oil mileage,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#45171 09/04/2004 3:07 AM
hey, 10-12 isn't that bad-i was doing good to get 8 on my 61 K20. but, the six is gone now, and without the O2 sensor, the TBI 350 isn't getting much better. think i'm gonna work on that soon...
"If the women don't find ya handsome, they should at least find ya handy!"
1961 Apache 20 4x4
http://community.webshots.com/album/97352016vHsKNP
#45172 09/04/2004 4:27 AM
Anonymous
Unregistered
Anonymous
Unregistered
Hey, have a '54 3800 panel(6800lbs emepty),17in. 750 12ply tires with stock 235 and a 4.10 rear end with a sm420 tranny. Took her on a 500 mile trip and averaged 9 miles a gallon and ONE quart of oil the whole trip.
tony'n weatherford grin
#45173 09/04/2004 4:36 AM
Tab Offline
Now I don't feel so bad getting around 14mpg in my, 62, 3/4 ton, long bed, stepside with a 235. I have gotten 17mpg in that truck but not since I had the motor rebuilt. I was hoping to get 20mpg. :•( Oh well, good thing I have a Honda that gets 40+mpg and a Harley that gets aroung 47mpg.
Speaking of gas: There are lots of stations here in N. TexAss running out of the stuff. Is a shortage in the offing?
delete my account and pictures
#45174 09/04/2004 4:43 AM
I'm getting 20-22 freeway with my 235, T5, 3.55s
Dennis
40 Chevy 1/2 ton
#45175 09/04/2004 2:22 PM
My 51 with a stock 261 except for a Holley 2 bbl gets 21 MPG on the highway with OD.My 37,modified 261, again with OD, gets around 19 on the road.
#45176 09/06/2004 1:52 AM
Junior Member
Junior Member
Wow! I have a '46 Chevy 1/2-ton with a '57 235ci and I am getting 18-20 mph. But then my top speed is is only 48-50 mph! i am running radials instead of 6-ply with tubes.
#45177 09/06/2004 9:40 AM
Since I have the dual Offy Holley/Weber setup I get 22 mpg at 65 mph out of a rebuild 235 on the Autobahn (freeway). Hope it is getting better with the overdrive I have waiting in the garage.
The gas is verry expensive in Germany
A gallon is almost 3,60$ over here!
Frank
#45178 09/07/2004 2:44 PM
I've driven on the Autobahn before-------if I tried to drive my 61 on the Autobahn we would be like one big speedbump!
Not quite as lean
Still a Marine!
#45179 09/07/2004 2:52 PM
For what its worth, Average MPG on our road trip from GA-CA and back was 12.6. 283V8 (.030 over) 3speed trans and 3.90 rear. Same as its done since 1976 on the road or in town.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
